Configure ACE IPv6 traffic class.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select IPv6.
- Select the Traffic Class tab.
- Select Insert.
- In Oper, select the operation type.
- In TrafficCls, type the traffic class number.
- Select Insert.
Traffic Class Field Descriptions
Use the data in the following table to use the Traffic Class tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq parameter specifies an operator for an “equal to” field match condition. |
TrafficCls |
Specifies the traffic class attribute of the IPv6 header. Traffic class identifies different classes or priorities of IPv6 packets. The range is 0–255. |
